Re: H starter switch
Posted by pat connors on April 01, 2004 at 10:50:18 from (192.223.243.6):
In Reply to: H starter switch posted by Barry Kiel on March 31, 2004 at 21:33:42:
I have a 41' H. My push button switch is mounted very low, in the middle of the frame next to the radiator shutter control lever. There was a hole drilled thru for the button portion, while the switch itself is mounted directly on the other side. It is easy to push by hand when starting from an un-mounted position. But if you are sitting in the seat, you have to use the toe of your boot.
Post a Followup
: Re: Re: H starter switch
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
