Re: Re: Re: Re: Re: Oiler Gear Gone On 1940 Farmal
Posted by lee on April 02, 2004 at 20:03:41 from (24.24.92.235):
In Reply to: Re: Re: Re: Re: Oiler Gear Gone On 1940 Farmall A posted by Brian on April 02, 2004 at 16:16:39:
In neutral, the countershaft is not rotating so the oiler gear gets to the spot where there are no teeth and stops turning. When you drive the tractor the countershaft is turning and the oiler gear (although free wheeling on the counter shaft) is turning into the reverse gear that drives it. Teeth are likely getting knocked off one by one. If you can devise some means to fix the position of the oiler gear, maybe wire it to the case, so it cannot turn you can fix the noise problem without knocking the teeth off.
Post a Followup
: Re: Re: Re: Re: Re: Re: Oiler Gear Gone On 1940 Farmal
