Re: Switch cub to coil and battery ignition
Posted by gene b on April 03, 2004 at 00:37:58 from (67.1.105.88):
In Reply to: Switch cub to coil and battery ignition posted by Tom Winn on April 02, 2004 at 19:07:55:
Make sure that the rotor is lined up with the terminal when it fores. When you put the new points in you changed the gears that run the rotor and got it off a few teeth.
Post a Followup
: Re: Re: Switch cub to coil and battery ignition
