Re: Overheating M
Posted by CNKS on April 03, 2004 at 13:28:02 from (207.178.99.132):
In Reply to: Overheating M posted by Josh on April 03, 2004 at 10:56:38:
I would take it to a radiator shop and have it rodded, with the understanding that the process might ruin the radiator if the corrosion is all that is holding it together. Happened to me once. Any tractor will overheat if it is overloaded. If you are running in 2nd, try 1st for a while (I know it is slow). If it still overheats, and your implements are not too big for the tractor, the whole system may need to be cleaned. Make sure your timing and carb are set right. But, since you have used it a lot, your radiator may well be the problem.
Post a Followup
: Re: Re: Overheating M
