Re: Re: Adjusting voltage regulator on a 43 CUB
Posted by Frank R. on April 03, 2004 at 17:14:40 from (209.247.222.85):
In Reply to: Re: Adjusting voltage regulator on a 43 CUB posted by Bus Driver on April 03, 2004 at 10:21:15:
yes, you are right I did not remember the date correctly. I will look that up again. Anyways, the regulator case has two coils in it. The right one appears to change the voltage to the battery, currently set at ~7.2 volts. The left coil has a adjustment locking screw in it but it does not appear to be adjustable.
Post a Followup
: Re: Re: Re: Adjusting voltage regulator on a 43 CUB
