51 farmall m hydraulic question
Posted by nick gehring on April 04, 2004 at 10:06:31 from (152.163.252.227):
I have a M that was set up with live hydraulics. I don't know if it is right. There is a pump that spins off the main belt. Its supplied with a hose comming from the drain plug of the belly pump. Then from the pump went to control valve. My question is can I feed that pump from one of the 90* fittings on the clutch side? Or better yet which fittings can I use to supply the control valves(I have 2 valves-2 remotes?) any help on this appreciated. Nick
Post a Followup
: Re: 51 farmall m hydraulic question
