560 TA same speed in or out ??
Posted by joe on April 04, 2004 at 12:39:58 from (205.146.39.100):
I just did an out of frame engine overhaul on my 560 gas that I bought used. No prior experience with this tractor. Did not remove the center clutch housing, but did look at the torque amplifier assembly through the openings in the housing. Everything looked good. I replaced the throw-out bearing and it would turn one way. I would guess the rollers act as a one-way clutch and this would be normal? However, now that the tractor is now all back together, it goes the same speed with the torque amplifier lever forward or back. The linkage is adjusted properly and I am SURE the torque amplifier clutch is disengaging. You can see it through the top inspection plate. What could possibly be wrong?
Post a Followup
: Re: 560 TA same speed in or out ??
