Re: IH 986 has no power going down road
Posted by RB on April 04, 2004 at 18:21:57 from (67.251.135.152):
In Reply to: IH 986 has no power going down road posted by Cody Spencer on April 04, 2004 at 17:16:37:
Check to see if the throttle control arm on the pump shaft is verticle with itself, it is spring loaded and if the high speed adjustment is limiting it, then it will be pulled back some. The high speed adustment is the acorn nut to the outside lower rear of the pump. Remove the nut and then loosen the thin nut and turn the slotted end screw out (counterclockwise) one round should show a difference.
Post a Followup
: Re: Re: IH 986 has no power going down road
