Re: Does anyone reproduce All-Fuel manifolds
Posted by CNKS on April 05, 2004 at 08:07:52 from (207.178.99.143):
In Reply to: Does anyone reproduce All-Fuel manifolds posted by will on April 05, 2004 at 07:55:48:
I don't know if there are repro's for the distillate/kerosene manifolds or not, there are several sources for the gas ones. I imagine that Mike at Steel Wheel Ranch will have a good used Kero/dist one -- 785-548-7437. Your carb will bolt on either, probably with no effect on performance.
Post a Followup
: Re: Re: Does anyone reproduce All-Fuel manifolds
