What I think: Cylinder wall themperatures are hotter at higher rpms because heat is being generated at a higher rate. Water circulation rate is also higher and water temperature remains about constant. Water circulation rate decreases at lower rpm so water temp around the cylinders increases. The higher temperature causes water to vaporize (bubbles) around the cylinders which displaces liquid water out the overflow. This is a temporary situation since the water flow slows immediately while the cylinders take time to cool to a lower temp.
If you don't refill the radiator, the water level will decrease to a point where it won't overflow anymore. If you keep the rpm's up for awhile after the load is decreased it may overflow less when rpm's are lowered.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
