Re: Farmall H
Posted by Paul in Mich on April 05, 2004 at 18:15:11 from (68.188.227.110):
In Reply to: Farmall H posted by Farm w/Junk on April 04, 2004 at 18:56:35:
Farm w/junk, The slot question has been answered, but not the starter question. The early models had the starter button switch mounted on the rear gas tank support as you described, however, there was also a 1/4" dia. pin that went through the steering post to the starter button so that you could push it with your foot. Beginning with the 1945's the starter button was relocated to the clutch pedal side of the steering post just below the light bar. As to the choke rod not having a place to mount, there was a square plate mounted to the steering post which accomodated the choke rod as well as the pulley control rod. The shutter control was also mounted there on models which had radiator shutters. Some models also had the ignition switch mounted on the same plate, although not all models, as some had the ignition switch mounted on the belly pump control rod bracket. The 1939 models had a mechanical ignition kill switch to the magneto which resembled a choke cable rather than the elictrical kill switch seen on most magneto ignitions. Since your tractor is a 1939, you have many features or the lack thereof exclusive of the newer models. In fact, some came with no starter, but hand crank. In that case, no choke rod went back to the operators platform, as they were choked while cranking. Nearly everything taken for granted on the later models were options in 1939 such as electric start, lights, belt pulley, pto, belly pump power lift, which if added later could be minus a few mounting parts. One thing you can do as time goes on is to attend a few tractor shows, and look for a 39 and see how things are arranged. You can also talk to owners as you come in contact with them and glean a lot of knowledge which they are usually eager to share.
Home
| Forums
Today's Featured Article -
Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
