Re: 706, shifting problem found...
Posted by MEK on April 06, 2004 at 06:22:17 from (148.177.1.212):
In Reply to: 706, shifting problem found... posted by matt on April 06, 2004 at 04:17:03:
Your tractor has been retrofitted with the more modern park lock from the 66 series tractors. Believe it or not, it's a much better system. The spring holds the park lock in place instead of gravity. It engages much more easily, and holds better.
Without the spring, you often have to rock the tractor back and forth by jumping up and down on the tire to get the lock to engage with the tractor on level ground. My Dad's 856 is like this, but the 756 and 1066 both have the spring loaded park locks, and work much better.
Post a Followup
: Re: Re: 706, shifting problem found...
