Re: Farmall H Carburator Adjustment screw settings
Posted by Wild Horses on April 06, 2004 at 10:18:29 from (216.51.163.251):
In Reply to: Farmall H Carburator Adjustment screw settings. posted by Dan on April 06, 2004 at 07:54:11:
Somebody correct me if I'm wrong, but I assume it's the same as an M. 3/4-1 turn out on the idle screw & 3 turns out on the power screw, both from seat. The idle screw is the needle valve that angles down from the front outside. The power screw is the one out the front of the bowl. These are just starting points. You will have to adjust and play with the settings to get the best results. YOu can do this by ear or on a dyno.
Post a Followup
: Re: Re: Farmall H Carburator Adjustment screw settings
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
