Re: 1952 farmall cub
Posted by Jeff_MI on April 06, 2004 at 17:54:58 from (24.247.143.159):
In Reply to: 1952 farmall cub posted by roger tomberlin on April 06, 2004 at 16:53:35:
I do two things that help troubleshoot the engine:
1. Remove the spark plugs and ground them to the chassis (one at a time). As the engine turns over, there should be a spark (be careful of gas fumes). If not, the plug or electrical is bad.
2. If there is a spark, squirt a little gas into each spark plug hole, put the plugs back in, and start it. It should run for a few seconds and stop. What I've found after doing this is either the engine keeps going and works fine, or the carburetor is gummed up. The last one I worked on, a BN, needed to be soaked in carburetor solvent; this was even after I soaked it in lacquer thinner and rebuilt it. It works great now.
Post a Followup
: Re: Re: 1952 farmall cub
