Re: rear wheels on super A
Posted by Bob on April 07, 2004 at 07:00:29 from (66.163.134.177):
In Reply to: rear wheels on super A posted by LANCE GRAFF on April 07, 2004 at 06:54:29:
The tractor was set up that way from the factory to "balance" the weight on the tires. Since the heavy tractor sits closer to the LH wheel, weight is added to the RH wheel to provide stability and traction.
Post a Followup
: Re: Re: rear wheels on super A
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
