Re: how to check differential gear oil
Posted by jal-SD on April 08, 2004 at 08:49:29 from (64.68.183.13):
In Reply to: how to check differential gear oil posted by bob missouri on April 07, 2004 at 23:45:20:
The idea of changing it is a good one. I've been around H's all my life & know that C's, H's & M's all like to collect water in the rear ends. I'd be suprised if you don't have a gallon or two of it in there. After it sets overnight (or longer) loosen the big plug under the back end (make sure the swinging drawbar is out of the way) & GENTLY screw it out by hand. Push in on it so when you get through the last thread, you can tip the bottom away from the casting. Do this when its rather cool out, so the grease is stiff. I'd be willing to bet big $$ that you get a lot of water out of there before any grease starts to run. Put the plug back in and then check the level. If the grease that runs out looks good-leave it-if not, change it. (My $0.02 worth. jal-SD)
Post a Followup
: Re: Re: how to check differential gear oil
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
