Re: Farmall H ........Trans. and Diff.
Posted by Wayne Swenson on April 09, 2004 at 07:27:54 from (66.228.234.115):
In Reply to: Farmall H ........Trans. and Diff. posted by Howard on April 09, 2004 at 04:47:05:
Hy-Tran is an excellent lube, BUT, it was developed for gear-trains that are manufactured to closer tolerances. It will lube just fine; it will give you a lot more gear noise.
85W-140 is about the best you can get now, unless you want the straight 140 gear lube. It is not easy to find, but I have seen it advertised in 5 gallon quantities in the "green" magazines.
Post a Followup
: Re: Re: Farmall H ........Trans. and Diff.
