Re: Farmall M Front End Wide to Narrow
Posted by Dick Davis on April 10, 2004 at 04:20:45 from (152.163.252.227):
In Reply to: Farmall M Front End Wide to Narrow posted by Richard Fazio on April 09, 2004 at 15:52:26:
Richard, when I went the other way -narrow to old style WFE (tie bars out front)- I found the spindles on the WFE were much smaller than the narrow. Had to use H or 300 wheels on the WFE. You might check before you get it immobilized. My nickel Dick Davis
Post a Followup
: Re: Re: Farmall M Front End Wide to Narrow
