Re: Carb Problem on 1939 Farmall H?
Posted by Bill Perry on April 10, 2004 at 09:41:27 from (152.163.252.227):
In Reply to: Carb Problem on 1939 Farmall H? posted by Craig on April 10, 2004 at 08:52:15:
Check fuel supply first. If you still have the strainer with the glass bowl on the bottom of the tank, shut off the valve, remove the bowl and clean the screen at the top of the bowl. You might also place a catch pan under the strainer assembly, open the valve and run some possible trash out of the tank. If someone has replaced the original with a fuel line and filter, replace the filter. How does it sound when it quits? Does it quit like the switch is turned off or does it sputter a few times and then quit. Are you loaded when it quits etc? Do you see fuel dripping out of the bottom of the carb. If you see fuel dripping out of the bottom of the carb then you are probably getting enough fuel and the carb is malfunctioning. Remove the intake air hose to the carb and if fuel runs out of there you have a sticking or sinking float or a needle valve sticking open. A single piece of a grass blade or a fleck of rust can stick the needle valve on the float open. Sometimes a good cleaning of the carb will cure the problem. When you confirm fuel is not the problem, go to ignition. More information if you need it.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
