Re: Farmall450 Power Steering Problem,Also TA Ques
Posted by Ron 1456 on April 11, 2004 at 09:41:26 from (207.32.34.63):
In Reply to: Farmall450 Power Steering Problem,Also TA Question posted by Harlen Larson on April 10, 2004 at 20:08:52:
Here is something you might try. Loosen the coupling that holds the steering shaft to the front of the power steering unit. With the engine running turn the steering wheel as far as it will go to both sides a couple of times and then stop back in the center. Retighten the coupler and try the steering again to see if it works better. Also with engine running while trying to turn the steering wheel pull one of auxillary valves that is not hooked up to anything. If the steering wheel turns easier when the valve is pulled the flow divider valve probably needs to be replaced. Good luck. Ron
Post a Followup
: Re: Re: Farmall450 Power Steering Problem,Also TA Ques
