Bad O-rings. Should I overbore and High compressio
Posted by phillip on April 11, 2004 at 15:25:05 from (4.229.171.176):
My 46 H with the C152 is leaking past the o-rings on the sleeves. Since I have to pull it apart anyway, should I bite the bullet and buy an overbore/high compression piston liner kit, or just fix the o-rings? Will the overbore kit with the stepped pistons require any modifications? Where is a good place to buy the kit? I plan on pulling it in the antique class and just putting around the yard with it. Would I be better off fixing the o-rings and milling the head? How much horse would I gain? Thank you in advance.
Post a Followup
: Re: Bad O-rings. Should I overbore and High compressio
