Re: Farmall A Died Suddenly
Posted by Larry on April 11, 2004 at 19:51:55 from (69.21.107.250):
In Reply to: Farmall A Died Suddenly posted by Larry Hardesty on April 11, 2004 at 14:45:09:
Is it our of fuel? OK just kidding. No really did you check? If it died it is either fuel or fire. LOL. All those people with their test lights are missing it. GO right to the coil and see if you have power there. If you do, place your test light right on the wire lead that goes into the distributor. When you turn the tractor over your test light should flash as the points short to ground. The easy way to test for fire is a screw drivewr in a spark plug wire.
Post a Followup
: Re: Re: Farmall A Died Suddenly
