Farmall Tractors Discussion Board
Pto Hydraulics on 1944 Farmall M leaking.
Posted by Rod Hergott on October 23, 1999 at 20:09:44 from (209.115.205.237):
The hydraulic system on the pto looks like a Char lynn but I couldn't find any identifying labels. The unit is sealed with only one seal on the front where a shaft comes out with a sprocket on it which is hooked up to the pto via a chain drive. This seal is leaking badly and I'm not in the mood to replace it before spring. What will happen if I leave the oil level below the level of the seal? How full am I supposed to fill the pump anyway? If I need a new seal can you tell me what size etc.? Help.
Thanks, Rod.
Post a Followup
: Re: Pto Hydraulics on 1944 Farmall M leaking.
