Re: Lesson on TA in 350U Wheatland Gas please
Posted by JLE on April 12, 2004 at 08:49:35 from (209.247.222.88):
In Reply to: Lesson on TA in 350U Wheatland Gas please posted by Sean in Calgary on April 12, 2004 at 08:22:45:
Sean: If you have adjusted the clutch pedal to correct height, then adjust the TA linkage to release the TA. It is the short adustable link going from Main clutch shaft to the TA shaft. Shorten link one turn at a time until you overcome the release problem. It wouldn't be as book says due to some wear. It is a pain in the
--- to shift with out proper adjustment. If you need more help E-M me. Jim
Post a Followup
: Re: Re: Lesson on TA in 350U Wheatland Gas please
