Re: Farmall H restoring questions
Posted by CNKS on April 12, 2004 at 17:58:19 from (207.178.99.130):
In Reply to: Farmall H restoring questions posted by Bob G on April 12, 2004 at 14:31:14:
Guy Fay's Letter Series Tractor book gives exact factory specs, you don't have to guess. Having said that, the the ODB or LHDB light switch decal goes on the light box adjacent to the switch, the one you use depends on whether you have 3 or 4 position switch, which depends on whether you have a cutout relay or voltage regulator. The high speed turn decal is centered on the top of the gas tank 1/2 inch in front of the gear shift decal. The top edge of the gear shift decal is centered on the gas tank 18 1/2 inches from the rear edge of the hood (or 18 1/2 inches from where the hood is supposed to lap onto the gas tank). The drawbar decal is centered on the rear of the seat pan 1 inch below the lip (this is mislabeled in Guy's book). The air cleaner is red, fuel cap red, I prefer the radiator cap unpainted (don't care how it was from the factory), original coil was red -- the new ones look ok black, unless you get a original style one, then it should be red.
Post a Followup
: Re: Re: Farmall H restoring questions
