Re: Re: Re: H -broke in half-
Posted by Hugh MacKay on April 12, 2004 at 18:31:07 from (64.228.11.175):
In Reply to: Re: Re: H -broke in half- posted by Hagan on April 12, 2004 at 16:35:46:
Hagan: May I remind you the frame rails are not cast. My dad broke them on the H and 300 both. The narrow front with loader puts a lot of strain on them especially narrow front comes to an obstacle and the tractor has enough traction to go over it. The wide front helps this a lot as most of the time both wheel don't hit and obstacle at the same time.
The M would take this much better as it had heavier frame rails. Oh course it's castings are heavier also. I'm kind of inclined to agree with that welder years ago, the castings will take it as long as they are tight. Even the slightest looseness and cast will be like pottery.
Post a Followup
: Re: Re: Re: Re: H -broke in half-
