Farmall Tractors Discussion Board
Re: Super A Govenor
Posted by ddg on October 24, 1999 at 04:19:09 from (152.163.204.212):
In Reply to: Super A Govenor posted by TimB on October 23, 1999 at 18:37:00:
No, I've had mine off a couple of times to replace thrust bearing or the gasket & you can take it off without removing anything. I had a little trouble working around the fan shroud though..........DDG
Post a Followup
: Re: Re: Super A Govenor
