Farmall Tractors Discussion Board
Re: white farmall cub ?
Posted by Phil Auten on October 24, 1999 at 04:39:26 from (206.175.72.226):
In Reply to: white farmall cub ? posted by gabriel on October 23, 1999 at 14:47:33:
Gabriel,
In early 1950, IH made several "White Demonstrator" tractors to mark the "Mid-Century".
The tractors were painted white with linkages and some other parts being red. The decals were the regular style and color. The CUB, A and C were the only models done this way. As Werf mentioned, there were cardboard inserts for the wheels and a sign on the hood. I just purchased a Motorbooks Calendar of Farmall Tractors 2000 and the photo for April is a White Demonstrator C with all the signs (reproductions). Check the serial numbers and casting codes on the tractor to determine if it is an early 1950 model. If so, it could be a demonstrator. I don't think any records exist of demonstrator serial numbers, so if you want to turn it into a demonstrator, go for it!
Phil
Post a Followup
: Re: Re: white farmall cub ?
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
