Re: IH 364 Trans/rear diff fluid change questions
Posted by JB on April 16, 2004 at 16:53:52 from (24.157.143.220):
In Reply to: IH 364 Trans/rear diff fluid change questions posted by Greg on April 16, 2004 at 15:14:31:
Hi Greg, I believe the 364 is newer model of B414D,434D,444D,384D. It has been a long time since we had 434D, you are correct the trans/diff use 80 or 90 gear oil. If you are in hot climate I would use 90 wt. Yes the full plug is on left side. I thought there was a drian plug on the bottom of the trans by the drawbar but maybe I am remembering the 454.
Good luck
JB
Post a Followup
: Re: Re: IH 364 Trans/rear diff fluid change questions
