Re: Cleaning gear oil off of concrete!
Posted by Aces on April 17, 2004 at 10:07:48 from (207.223.245.165):
In Reply to: Cleaning gear oil off of concrete! posted by 49 Cubber! on April 16, 2004 at 17:52:43:
49 This I have used many times and it will cleaning solvent, desiel, work it into the spot good and then a good coat of (floor dry) not the cat junk, when it has set long enough to dry good sweep it up you will have a clean floor.
Post a Followup
: Re: Re: Cleaning gear oil off of concrete!
