Re: Want to crank Super H
Posted by Bob M on April 19, 2004 at 07:37:23 from (165.170.128.66):
In Reply to: Want to crank Super H posted by Neal in Alabama on April 18, 2004 at 20:03:16:
Neal - You can crank the engine simply by connecting your negative jumper cable to the starter switch terminal (the heavy switch mounted on top of the starter), and positive jumper to the tractor frame. Then crank the motor by working the starter switch rod. Just make sure the ungrounded battery cable terminal is protected from contacting grounded metal in the battery box (wrap it with tape, etc) before making the jumper connections. If your ignition wiring is intact you can run the tractor jumpered up the same way. But in order to not cause any damage, first remove the wire from the BAT terminal on the regulator. Also limit run time to only a few minutes. Otherwise feeding the coil 12 volts without a series resistor can cause it to overheat and may also burn out the points.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
