Re: What are the odds of cheap rebuild?
Posted by TMAC on April 22, 2004 at 02:46:20 from (207.144.6.52):
In Reply to: What are the odds of cheap rebuild? posted by MM on April 21, 2004 at 20:05:52:
I have had the fortune of working on two stuck engines that had recent overhauls just before they were retired and forgotten. All they needed were a good cleaning of the cylinder walls and unsticking of the rings. The engines now run with good compression, no smoke, and good oil pressure.
Post a Followup
: Re: Re: What are the odds of cheap rebuild?
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
