Re: Re: Oil Change Intervals
Posted by Andy on April 22, 2004 at 10:05:32 from (12.2.73.20):
In Reply to: Re: Oil Change Intervals posted by Bob M on April 22, 2004 at 06:51:27:
Bob,
I agree with almost everything you said except that oil cannot degrade or "wear out". This may be true for the basestock (either petroleum or synthetic), but it is not true for the additives in the oil. Long polymer chains are commonly used to increase the viscosity of the oil and will do break down with use. Also, other additives in oil such as anti-oxidents, anti-corrosion agents, and so forth will be "used up" over time.
Also, each brand of oil uses different additives (thus different brands will last longer and perform better). NOT ALL BRANDS OF OIL ARE THE SAME.
Post a Followup
: Re: Re: Re: Oil Change Intervals
