300 seems to miss when idleing
Posted by Bkpigs on April 01, 2009 at 19:07:52 from (75.132.238.145):
my 300 runs great except when it is running with no load. It doesn't make a difference if it is at low or high idle. Once a load is put on the motor she purrs like no other. The tractor ran like this ever since my dad bought it about 30 years ago. Can anyone think of the possible reason. I cleaned the carb, replaced plugs and wires, and replaced the conventional points with an electronic one. I also put a high output coil on it. None of this seemed to change anything. Any ideas, if not she does great the way she is :)
