Old Farmall QUESTIONS
Posted by Charlie on April 24, 2004 at 17:33:01 from (207.230.43.142):
GOT a 1942 mod. M (I THINK) ,the tag looks to be original,attached with four brass studs. It's in good shape and not bent or damaged in any way. However, the only thing legable is the ser. number 52923 which is stamped into the metal, no FBK is legable. There are traces of other info. present The engine no. is 52214. The rear axle housing casting dates are left 9-27-1 or I AND RIGHT 1-12-1 OR I not sure of the last digit. The main rear diff. housing has part no. 8002DD AND CASTING DATE 1-20-L On the front pedistol ( narrow front) reading from top to bottom vertically are casting mark 11-12 and in raised fancy script letters the word Belectromal. Q. No.1 ,is this info. consistent with 1942. Question 2 Did all M,s ,even the early ones have FBK before ser. no. Q.no. What is significence of the word BELECTROMAL . THANKS IN ADVANCE.
Post a Followup
: Re: Old Farmall QUESTIONS
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
