Re: Re: Re: Hot H hydraulics
Posted by Bob M on April 26, 2004 at 09:48:36 from (165.170.128.65):
In Reply to: Re: Re: Hot H hydraulics posted by Doug on April 26, 2004 at 08:54:06:
Doug – Sounds like the hydraulic pump is still partially loaded even when the valve is in neutral. Otherwise there is no way for the pump/system to get hot while running (it should be only slightly warm).
Don't be too hasty about removing the live pump! It’s a pretty handy thing to have – especially with a 3 point.
Suggest working the valve handle around to try to find the true neutral position. By listening for changes in idle speed/pump sound you should hear it load/unload as you move the handle. Could also be there’s something wrong inside the valve itself so the tank return port is partially blocked even when the valve is in neutral.
I presume your reservoir/valve is the standard Farmall “Liftall” unit?
Post a Followup
: Re: Re: Re: Re: Hot H hydraulics
