Re: electronic ignition fried!!!!!
Posted by Bob M on April 26, 2004 at 10:43:03 from (165.170.128.65):
In Reply to: electronic ignition fried!!!!! posted by Ron on April 26, 2004 at 09:58:56:
Ron - I’m not familiar with that particular tractor nor it’s electronic ignition. However a couple possibilities to check out:
1 – The ballast resistor has shorted causing the distributor module to see 12 volts after the starter is disengaged. If the ignition system was designed to have the ballast resistor this could well cause the module to overheat/burn out.
2 – The generator was not properly polarized after being rebuilt/reinstalled. That could send current of the wrong polarity thru the ignition module - could then fry it quick!
Post a Followup
: Re: Re: electronic ignition fried!!!!!
