Re: Hooking up Charlynn PS Unit
Posted by Doc on April 27, 2004 at 00:31:15 from (24.118.46.109):
In Reply to: Hooking up Charlynn PS Unit posted by John/Pa on April 26, 2004 at 17:56:18:
I mounted an older GM pump in the same spot as Farmer Bob (used his pics as guideline, thanks Bob). I held the pump in place and started fabricating brackets. I use the same belt for pump and alternator. I used an older pump so I had SAE, not metric fittings. I went to a hydraulic shop and got hoses made. To do it over I would probably get the steering motor mount from Steel Wheel Ranch. This replaces the current center steering shaft mount and gauge mount. Saw a pic and it looks good. Also may want to get the angled shim to set the steering motor at the right angle. It is a bit of work to get things in place, but well worth it.
Post a Followup
: Re: Re: Hooking up Charlynn PS Unit
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
