Re: Re: Re: checking H- engine Oil
Posted by jal-SD on April 27, 2004 at 06:56:48 from (64.68.183.22):
In Reply to: Re: Re: checking H- engine Oil posted by rustyfarmall on April 27, 2004 at 05:11:46:
I'm with Rusty, add a quart if it doesn't run out the top petcock. We farmed 880A with four H's when I was a kid, & I can tell you from experience that an H does not care if its oil is a little over full. Originally, the two petcocks were for kero/diso burners, they all diluted the oil. Each day before you put them to work, you were supposed to drain the lighter diluted oil off the top of the pan down to the level of the bottom petcock & then fill them up to the top one with 30W. IH never bothered to change the pan for X-1 models, although I've seen X-1's with a pipe plug in the bottom petcock hole. I don't know if this was factory or an "after-market" modification. (My $0.02 worth. jal-SD)
Post a Followup
: Re: Re: Re: Re: checking H- engine Oil
