super M 2nd. stage, hydralic problem
Posted by scruffy on April 27, 2004 at 18:46:40 from (64.228.61.187):
I was tryin' out my Super M and newly acquired plough, and on the last pass heard a change in the engine sound, alot of blow-by had started and noticed my oil presure was very low. Shut her down and checked the oil. I pulled the dip-stick and oil came spraying out. It had about 3 gallons in the pan. When I put my discs on last week, noticed my hydralics wouldn't lift so I put about two gallons of hy-tran in the tank. Well it didn't stay there...(at least it wasn't antifreeze.) This M has the pump in front of the distributer, is there a seal that can be easily replaced between the pump and the housing or am I going to be looking at a pump o/h?
Post a Followup
: Re: super M 2nd. stage, hydralic problem
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
