Re: picture of H with cultivator?
Posted by Dick Davis on April 28, 2004 at 07:53:38 from (64.12.117.22):
In Reply to: picture of H with cultivator? posted by Corey R on April 28, 2004 at 07:16:09:
Guy Fay's book "International Harvester Tractor Data Book" has an H with two row cultivator on the cover. The book is published by MBI and probably available on Amazon. Good luck with your project. Mine is 3/4 done need to blast/paint shanks and find the connector from the front half to lift the back half. Dick Davis
Post a Followup
: Re: Re: picture of H with cultivator?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
