Re: Installing One Piece Crank Seal -- Dumb Questi
Posted by Allan on April 28, 2004 at 14:15:31 from (148.63.132.164):
In Reply to: Installing One Piece Crank Seal -- Dumb Question posted by RCWILBUR on April 28, 2004 at 13:47:34:
Hi RC,
All one piece seals are "supposed" to be installed using the proper tool.
However, if you are very careful, they can be gently tapped into place using a light hammer. Lube the riding surface & seal lip before you start in on.
Allan
Post a Followup
: Re: Re: Installing One Piece Crank Seal -- Dumb Questi
