Re: 300 Torque amplifier
Posted by Blackland Dan on April 01, 2009 at 19:59:27 from (206.248.34.106):
In Reply to: Re: 300 Torque amplifier posted by Kevin Meier on April 01, 2009 at 18:20:40:
Thanks, Kevin. You're probably right about the work part. I actually don't mind that because I learn a lot by taking things apart and putting them back together. However, I may take you up on one of your TA's. Mine is a standard 300 w/belt pully. Where are you located? Dan
