Farmall Tractors Discussion Board
Re: h needs more power
Posted by justin on October 25, 1999 at 20:11:28 from (209.83.211.105):
In Reply to: h needs more power posted by ken on October 25, 1999 at 19:59:39:
To add more power, here are your options:
put in oversize pistons
Put in oversized pistons with special piston design such as step head, firecrater, or M&W
Bore the block, and put in Super H pistons (you could also place the special design pistons in)
I'm not sure what piston it is, but I have been told that you can place a 300/350 piston in the bore of an H (with sleeve removed) but I wouldn't do this..
You may also want to see what head you have on the tractor.. A dist/kero head is a lower compression head than a gas head..
Good luck..
Post a Followup
: Re: Re: h needs more power
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
