Re: 340 TA
Posted by Aces on April 30, 2004 at 10:18:06 from (67.0.38.13):
In Reply to: 340 TA posted by lincoln on April 30, 2004 at 09:44:08:
Lincoln The TA is a high low shift on the go forward is high back is low. for light work as you said it should be forward and never cost down hill with it back never shift it back after you start down hill so as to cost, if you are plowing or disking down you can have the lever back.
Post a Followup
: Re: Re: 340 TA
