Re: Leaking M carbs
Posted by Ibby on May 01, 2004 at 04:37:34 from (64.14.92.197):
In Reply to: Leaking M carbs posted by harley1983 on May 01, 2004 at 01:51:03:
I've the same problem with both my 350U and 450. I found that if you retard the throttle all the way down before shutting it off, it'll stop the dieseling. AS far as gas leaking out of the carb - been there, done that 1.6 gazillion times. It's critical to install a new seat with a new needle, and get the float height right. That don't always solve it, but it'll help. On the 350, A rubber tipped needle solved the problem. Still looking for the trick to keep the 450 from spewing. If you're not concerned with 100% originality, put an inline fuel filter in the line to get the small gunk that makes needles sticky. Good luck!
Post a Followup
: Re: Re: Leaking M carbs
