Re: Re: Re: Re: Dishonest Seller
Posted by Chris Brown on May 01, 2004 at 08:12:02 from (209.206.208.42):
In Reply to: Re: Re: Re: Dishonest Seller posted by Jesse on April 29, 2004 at 10:30:57:
If you can prove that the seller falsely represented an item and you can prove it. It is not slander and you are not guilty of liable. That is why it is important to get it all in writing or to save all emails and pictures. If you go on to give out his name and a story about what he did to you,be truthful. If he decided to sue you for this,it would be the best thing for you because you saved all correspondance and a history of what happened. It is called a counter suit and you know he will show up.
Post a Followup
: Re: Re: Re: Re: Re: Dishonest Seller
