Re: Got the old M running now have a couple questi
Posted by BIG JOHN on May 01, 2004 at 18:20:11 from (64.12.117.22):
In Reply to: Got the old M running now have a couple questions posted by Paul G. in Mn on May 01, 2004 at 18:01:21:
If you had the carb off chances are that it is that you did not get the govenor shaft in correct when you put the carb back on. Redo your work and see if that doesn't fix it.
If this is not the case then you need to go into the govenor and clean it up good because that it more than likely where your problem is.
GOOD LUCK
Post a Followup
: Re: Re: Got the old M running now have a couple questi
