Re: 686 - any good?
Posted by Russ on May 02, 2004 at 16:10:48 from (24.61.107.193):
In Reply to: 686 - any good? posted by RED-ED on May 01, 2004 at 19:28:39:
686; 6 CYL, 312CID DSL, XMSN 10F-2R, 66.3 HP PTO, 7570 LBS, LO 4560, MID 5630, HI 6360. ONLY A GUIDE. PRACTICE PUTTING ON YOU HIGH QUALITY EAR PROTECTION MUFF'S. HEAVEN HELP US ALL IF YOU LOCK UP TWO GEAR'S WHEN ONE IS ENUF. GOOD LUCK ON YOUR BID.
Post a Followup
: Re: Re: 686 - any good?
