Re: Head Gasket ???
Posted by jed on May 03, 2004 at 07:28:35 from (66.212.143.210):
In Reply to: Head Gasket ??? posted by Tom on May 03, 2004 at 06:43:53:
Head gaskets are standard out to 4 and 1/8th. No water jacket cracks aren't normal. I would think that they could run on you. I reuse head gaskets and add the high temp. gasket maker. I also add an extra 5 psi of torque. Also make sure the gasket isn't broken anywhere.
Post a Followup
: Re: Re: Head Gasket ???
